Wiring diagram for a 84 delta 88
Old July 11th, 2018, 02:47 PM
Jon Woods's Avatar
Hey all, Im in need of a diagram for an 84 delta 88. My ecm/dec fuse keeps blowing and throwing a check engine light, causing it to run rough and bog from a stop. Id like to trace this wire and find the problem. Any ideas or words of wisdom?
Jon Woods is offline
Old July 11th, 2018, 03:57 PM
There isn't "a" wiring diagram, there are a hundred pages of diagrams of each individual circuit. There are currently a dozen or more of these manuals on ebay. The cheapest one I found in a 30 second search is $9.50 with free shipping.
joe_padavano is offline
Old July 11th, 2018, 08:03 PM
Jon Woods's Avatar
That boggles my mind as to why GM needs a hundred pages per circuit while the same year toyota with fuel injection needs 4 for the entire car. Thanks for steering me in the right direction.
Wait I see, it covers all oldsmobiles for that year, thats more understandable.
Old July 12th, 2018, 07:15 AM
It's not 100 pages per circuit, it's about 100 pages for each car line. First, this is the Electrical TROUBLESHOOTING Manual, not just the wiring diagram. Each circuit (headlights, turn signals, power distribution, grounds, power seats, etc) gets at least one page with a dedicated wiring diagram of ONLY that circuit. This makes it a lot easier to read. THEN, there are subsequent pages for each circuit that describe how the circuit works, how to troubleshoot it, what the voltages and resistances are at each point for testing, and where the components are located in the car. It's much more than a wiring diagram. It probably also is exactly what you need to find your problem.
Old July 12th, 2018, 05:20 PM
And the GM electrical books are much better than anything offered at the time. I stopped turning wrenches for a living 20 years ago, did the other automakers catch up and improve their manual?
matt69olds is offline
Old July 12th, 2018, 07:49 PM
Jon Woods's Avatar
Ok I understand now. That should be more helpful then just a diagram and definitely worth it. Thank you. I did not find the one for $10, but found one close enough that its on its way.
No idea matt, Ive mostly dealt with 80s yotas and have never had an issue using their FSMs. Ive found the chiltons and haynes are the only ones that lack real information.
bob provost
April 7th, 2018 08:43 PM
SeabeeMechanic
October 12th, 2015 05:08 PM
neatolds
August 19th, 2015 11:44 AM
m371961
January 12th, 2013 06:21 PM
71cutlass455
February 18th, 2010 09:16 AM
Quick Reply: Wiring diagram for a 84 delta 88
