Cornering lamps
Cornering lamps
65 98
Does anybody know where in the manual the wiring diagram for the cornering lamps is located?
The full wiring diagram ( chassis manual figure 13-2), does not show it. Looked around and did not find it. I believe I have them working correctly now, but would like to see the drawing.
I don't have a 65 manual but in the 66 manual, the full wiring diagram (figure 12-4) shows the cornering lights. The power source to the switch is tapped to the supply for the underhood lamp and glovebox light that feeds through a 9 amp fuse on the fuse block. The cornering lights are also shown in the Accessories section (figure 15-79) but there is no detail. My aftermarket laminated wiring diagram also shows the cornering lights.
