Cornering lamps
Old Jan 12, 2013 | 05:39 AM
m371961's Avatar
Cornering lamps
65 98
Does anybody know where in the manual the wiring diagram for the cornering lamps is located?
The full wiring diagram ( chassis manual figure 13-2), does not show it. Looked around and did not find it. I believe I have them working correctly now, but would like to see the drawing.
Old Jan 12, 2013 | 08:30 AM
bigoldscruiser's Avatar
2 '66 98's
I don't have a 65 manual but in the 66 manual, the full wiring diagram (figure 12-4) shows the cornering lights. The power source to the switch is tapped to the supply for the underhood lamp and glovebox light that feeds through a 9 amp fuse on the fuse block. The cornering lights are also shown in the Accessories section (figure 15-79) but there is no detail. My aftermarket laminated wiring diagram also shows the cornering lights.
Old Jan 12, 2013 | 05:45 PM
m371961's Avatar
Thanks, I'll take a look at that. Where did you get an aftermarket diagram?
I have a chassis manual on disc, and the wire diagram just isn't right.
Old Jan 12, 2013 | 06:21 PM
m371961's Avatar
As the young folks say, my bad. As us older folks say, sorry. Looked at wrong diagram.
pfb53
May 18, 2014 08:26 AM
mugzilla
Dec 20, 2009 05:46 PM
grt05
Hurst/Olds
May 3, 2009 10:40 AM
sklbndt
Feb 12, 2009 06:36 PM
