wire harness
Old Jun 22, 2024 | 02:21 PM
jerryl's Avatar
wire harness
i am currently installing under dash harness in 69 442 ,i found two wires near tilt column one is orange w/black the other is pink the ignition switch has two male connectors on one end but not sure if they get connected to this
Old Jun 22, 2024 | 02:37 PM
And....you don't own the 1969 GM Oldsmobile CSM which contains all the wiring diagrams?
There are minor differences between the 69 4-4-2 regarding wiring from all other 69 A-Body wiring.
Why not look here and evaluate the color wiring diagram for the 1969 V8 A-Body...
A picture of what you're viewing would assist, as well.
1969 Wiring Diagrams
Old Jun 22, 2024 | 05:51 PM
Loaded68W34's Avatar
If the orange/ black and the pink are in a single 2-wire connector, they are for the gas pedal activated kickdown switch on a TH400 transmission. Cars not equipped with a TH400 (manual trans or TH350) still have the connector in the harness, it is just taped up out of the way and not used.
Old Jun 23, 2024 | 05:37 AM
jerryl's Avatar
each wire is a single connector
Old Jun 23, 2024 | 07:00 AM
I think Tom (Loaded68W34) is correct regarding wire/function, but not the single two-wire connector; I also believe the OP (Jerryl) is correct regarding two single-wire connectors.
With no first-hand experience involving the TH400 transmission wiring; yet, having reviewed the wiring diagrams between 1968 - 1972 & recalling several previous discussions pertaining to the TH400 downshift solenoid note the following:
...the 72 TH400 will have a two terminal case connector...
JoeP >>> th400 kickdown solenoid check
Recall introduction of the TCS (Transmission Control Solenoid) beginning 1970. The delta in wiring exists w/ the introduction of the TCS where the connector wiring contained two single-wire connectors prior to the TCS and a single double-wire (two terminal) case connector post-1969.
Black w/ single Orange stripe is for the pedal activated (downshift solenoid) kick-down switch if equipped w/ a TH400 transmission - if no TH400 the connector is not connected but left up under the dash in the area of the column.
The pink wire I'm not 100%. I suspect it's either the IGN SW (pink wire) or the Parking & Low Brake Warning Lamp instrument cluster wire which feeds from the (if equipped) TH400 transmission switch; I suspect the latter.
End of day, I believe the 1969 (if equipped w/ TH400) had independent single-wire connectors. Hang tight, someone w/ specific/more knowledge will validate/invalidate.
Old Jun 23, 2024 | 08:45 AM
Actually that would be Transmission Controlled Spark, used 1970-72. The addition of the federally-mandated EGR for the 1973 model year replaced the TCS system as an NOx reduction method.
Tree007
Dec 3, 2023 03:16 PM
skyhigh
Sep 2, 2022 05:07 AM
Puppy boy
Apr 14, 2021 07:58 PM
70-455
May 22, 2020 12:58 PM
76CutlassSalon
Jul 4, 2016 08:17 PM
