This wire
Old May 27, 2019 | 12:43 PM
F85 330 ctls's Avatar
This wire
I changed my ignition and ignition switch and noticed this wire dangling, as you can see it’s an orange wire connected to a brown wire, my car is a 67 f85 330 v8 Any help would be appreciated,thanks again.
Old May 27, 2019 | 12:59 PM
It looks like it's an accessory item. Looking at your fusebox, I would disconnect the battery and give those contacts a serious cleaning.
Old May 27, 2019 | 03:41 PM
CRUZN 66's Avatar
Olds Fever
Just to clarify photo view, is the orange wire cut or does it go to the back of the fuse box??? X2 that it may be an accessory wire...
Old May 27, 2019 | 06:31 PM
The orange wire comes out of the wire harness and that wire is connected to the brown wire.
Old May 27, 2019 | 11:57 PM
rcorrigan5's Avatar
Randy C.
If that brown wire goes through the firewall and into the engine compartment, it could very well be the hot connector for your underhood light.
Randy C.
Old May 28, 2019 | 10:37 AM
bry593's Avatar
1968 442 Convertible
Orange is 12V power all the time with the key off. Yellow is key on 12V. The orange wire goes to clock, cigarette lighter, glove box light, map/dome lights and courtesy lights. When using an aftermarket radio, connect orange to the memory wire. White is ground wire for dome and courtesy light switches.
Not sure why a brown wire is attached to it. Might be someone had gotten creative at some point. There is a brown wire that plugs into the HVAC, but it is clearly not to be plugged into an orange wire.
Old May 29, 2019 | 10:31 AM
Thank you
70 ctls
Aug 23, 2024 08:56 AM
friesjh
Sep 18, 2019 07:09 PM
Icee5150
Sep 1, 2013 10:16 AM
stingger68
Mar 2, 2010 04:12 PM
Deputy442
Sep 2, 2008 10:58 AM
