wiper switch weird
Old Jan 27, 2012 | 06:35 PM
centonze's Avatar
wiper switch weird
Hi guys,
I am having a problem with my windshield wipers. They function great, but only when i turn the ignition in the accessory position. They do not work when I turn the ignition forward or when the car is running. Don't think I'll pass inspection until I fix this problem.
Any ideas what cold cause this?
Old Jan 27, 2012 | 06:44 PM
Lady72nRob71's Avatar
First time I heard of this kind of issue. What car and year?
Does the radio do the same thing? It runs off the accy terminal of the ignition switch also.
HAs the wiring been hacked by a previous owner?
If the radio acts the same and no hacks are evident, I suspect an internal contact in the ignition switch may have failed.
Old Jan 27, 2012 | 06:57 PM
Rob, it's a 72 Cutlass S
Centonze, this troubleshooting is on page 12-46 of the 72 Chassis Service manual. Have a look: http://wildaboutcarsonline.com/membe...ection_12B.pdf
Old Jan 28, 2012 | 06:20 AM
centonze's Avatar
Thanks, i'm going to check the internal contact in the ignition switch. The wipers worked correctly until recently. I haven't fiddled with the wiring.
Thank you, i will post when i find out.
Old Jan 28, 2012 | 03:21 PM
If it helps any, I had a similar problem with my 83. Only the washer and wipers wouldn't shut off! Right on the highway. Drained my washer fluid in about 2 miles. Had to pull over and disconnect the wipers connection. Hooked it back up to see if it would 'reset'. Nope. Ended up replacing the wiper motor. Suspect you might be in the same boat leaving a different port.
gwunta
Jun 22, 2024 08:59 AM
oldspackrat
Mar 12, 2015 06:34 PM
brandon reynolds
Dec 18, 2013 03:05 PM
centonze
Jan 17, 2012 07:04 PM
1BAD68"S"
Brakes/Hydraulic Systems
Nov 17, 2006 04:20 PM
