what resistance is this wire,
Old Dec 1, 2013 | 07:12 AM
Jacob Wilson's Avatar
I hooked it up to my voltage regulator but could not get a solid read. it is the ignition coil resistor wire.
Old Dec 1, 2013 | 07:22 AM
They are usually about 1.3-1.6 ohms.
Old Dec 1, 2013 | 08:35 AM
rustyroger's Avatar
'87 Delta 88 Royale
Check it with a digital multimeter. a tool that should be in every toolbox nowadays.
Roger.
Old Dec 1, 2013 | 08:41 AM
Octania's Avatar
"I hooked it up to my voltage regulator"
Old Dec 1, 2013 | 08:58 AM
Yeah, but at least it was accompanied by a photo of a generic black wire, so that clarifies it...
Seriously, what exactly are we talking about here? Is this the resistance wire to the coil? I assume by "voltage regulator" you meant volt-ohm meter? What scale were you measuring on? As noted, the resistance is pretty low, so hopefully your meter has a scale that's appropriate.
Old Dec 1, 2013 | 09:49 AM
BILL DEMMER's Avatar
Just the facts...
bill
Old Dec 2, 2013 | 12:59 AM
nsnarsk65cutlass's Avatar
It looks like a black wire to me, the ignition coil resister wire is a white fabric covered type wire.
DocAS
Jul 8, 2014 10:55 AM
woodie582
Feb 8, 2013 06:57 PM
RandyS
Sep 12, 2012 02:40 PM
defiant1
May 3, 2011 08:52 PM
jag1886
Jan 12, 2011 07:37 AM
