Washer wire color
Old May 16, 2019 | 12:43 PM
Cruiser Bob's Avatar
Washer wire color
Which years used pink and white wires to the washer
Old May 16, 2019 | 05:48 PM
I know for a fact my 83 GMC truck I’m working on has pink and white wires for the washer. I’m guessing anything with an electric washer pump would be the same
Old May 17, 2019 | 05:32 AM
The reason I asked is the Trico 11515 replacement pump for the mechanical washer pump has many notes on which wire go where, and only talk about pink and white wires. My 71 cruiser has yellow and blue.
Old May 18, 2019 | 07:21 PM
The yellow and blue I believe powered the solenoid to engage the mechanical washer. Use a test light, with the key on check for power on the yellow wire. Then check for continuity to ground with the wash button pressed. Good luck
Old May 18, 2019 | 08:40 PM
Thanks for the reply, all the wiring and switch are good , what I am curious about is why the 11515 is listed as not compatible with the 71 cruiser.
Rlasley
Jun 10, 2018 03:40 PM
Roger60
Dec 15, 2017 09:13 AM
ELECMAN
Feb 29, 2016 07:35 PM
mkenny
Sep 29, 2015 09:08 PM
ND71
Nov 7, 2009 09:32 AM
