72 olds 442 washer problem
Old Feb 29, 2016 | 05:08 PM
ELECMAN's Avatar
I don't know if I'm saying this right,But when you push the washer button in its suppose to send a pulse ground to the solenoid which engages the wash cycle.when I touch a ground wire to the solenoid it engages telling me that the solenoid is good.What should I check for next put a new switch in thinking the old one was bad.
Old Feb 29, 2016 | 07:35 PM
Make sure the tubing and screen are not clogged from the reservoir to the pump. Then make sure the washer tubes are not clogged from the pump to the windshield. If all is clear, then replace the pump on the bottom of the wiper motor assy.
PhillK
Apr 14, 2015 11:14 AM
tdhill01
Jul 6, 2014 08:06 PM
tdhill01
Jul 6, 2014 08:06 AM
scumdog
Oct 30, 2011 11:00 PM
ELECMAN
May 19, 2010 06:00 PM
