Under hood wiring
Old Mar 6, 2014 | 06:07 PM
sea442's Avatar
Under hood wiring
I quit drinking 7 years ago.....starting to rethink that as I bought a project car! Here is what I got, 68 olds. 442. I purchased new wire harnesses for the engine compartment, both the engine and front lighting. After hooking everything up I put in the battery. Why would the tail lights and under dash lights come on when they have not been instructed to do so? Is the relay on the inner fender the horn relay? It has a red wire that comes from the alternator on 1 terminal, a wire coming from the positive terminal off the battery on another terminal, pink w/black wire, dark green wire, and black wire with spade terminals. Not that it was he right thing to do but I took the wires off from the old and replaced them on the new.??? Why must those tail lights do this to me?
Old Mar 6, 2014 | 06:21 PM
Ceilingman's Avatar
I have 69 convert if you wanna look at the wiring, I am in Kearney
Old Mar 6, 2014 | 06:40 PM
sea442's Avatar
Seein is believin! Send me your info please, I get with sometime + I want to see your car!
Old Mar 6, 2014 | 06:52 PM
Ceilingman's Avatar
Call me Tommorow sometime 308-440-0675
Old Mar 7, 2014 | 03:23 AM
Yellowstatue's Avatar
The horn relay is also the junction block and buzzer for the key (pink wire).
Old Mar 7, 2014 | 04:58 AM
Beob's Avatar
The headlight switch could be bad but, the only way to find the problem is with a test light or voltmeter and a wiring diagram
Rickman48
Mar 23, 2013 01:06 PM
74droptop
Nov 1, 2012 10:13 AM
CTWalneck
Jan 12, 2004 12:32 PM
CTWalneck
Jan 12, 2004 12:30 PM
<CTWalneck>
Jan 12, 2004 12:05 PM
