Turn signals not flashing
Old Oct 20, 2017 | 12:27 PM
rick442's Avatar
Question Turn signals not flashing
Just finished restoring my 442. I put the bumpers and lights back in. I installed LED bulbs.
The turn signals light but do not flash. I can manually move the turn signal lever up and down and the tail lights blink. The emergency flasher mode does blink the tail lights.
I replaced the turn signal flasher "Fuse". That did not change.
Any ideas?
thanks!
Old Oct 20, 2017 | 12:57 PM
Do you have a flasher suitable for the use of LED's or are you trying to run the stock units?
Old Oct 20, 2017 | 01:39 PM
rick442's Avatar
just running the stock unit. Would a heavy duty work? OR do I need a specific. I put LED's in my Cuda and had no issues. So I just assumed stock would be fine. :P
Old Oct 20, 2017 | 01:41 PM
You need led specific flashers.
Old Oct 20, 2017 | 01:42 PM
The stock electromechaical flasher uses the current draw of the original incandescent bulbs to head the bimetallic strip in the flasher that opens and closes the circuit. If you've gone to all LEDs, you likely don't have enough current draw to heat up this strip. You need an electronic flasher module that has a solid state timing circuit instead of a bimetallic strip. And be sure to replace the turn signal flasher under the dash. The one on the fuse box is for the hazard flashers (and that one needs to be replaced also for the hazard flashers to work).
Old Oct 20, 2017 | 02:31 PM
rick442's Avatar
ah!! Thanks guys. I appreciate the help and education. 'Lord knows I need. :P
I just ordered one.
Old Oct 20, 2017 | 03:14 PM
You need 2 as Joe P stated. One for the directionals and one for the hazards.
Old Nov 7, 2017 | 05:52 PM
oldsjoe's Avatar
Thanks Joe P I too have been chasing this gremlin for months. I've tried three different flashers don't think I tried two electronic flashers in the fuse panel and the under dash unit. Will get out there and try that in a couple days. Joe
Sep 24, 2017 12:56 PM
car_designer
Jul 11, 2015 08:00 PM
73aussie455
Sep 23, 2014 04:10 AM
kevin.horton
Mar 26, 2012 07:12 PM
jpaulwhite
Mar 27, 2010 08:38 PM
