Turn Signal Switch problem
After I installed the TSS and put the column back together, the last thing I did was screw in the flasher ****. I tried the flasher out a couple of times and on the second try the **** pulled out. Tried to srew back in but it was stripped. Called Fusick and they sent me a new one. When I examined the new one I found the srew hole to be slightly larger than the original and its not threaded. So the hole is bigger with no threads, is this normal, has anybody else had a problem like this?
Thanks, Rob
pic 1 - old TSS
pic 2 - new TSS
pic 3 - tape shows how far ice pick went in on new TSS
Thanks, Rob
pic 1 - old TSS
pic 2 - new TSS
costpenn
June 24th, 2015 10:38 PM
dennisspeaks
October 1st, 2011 06:02 PM
