Turn Signal Switch Connector
Old Apr 22, 2023 | 08:38 PM
Odie89's Avatar
I am installing an American Autowire kit into my 1971 Cutlass. I have attached the pictures. The connector in the kit is missing 2 wires (first pic). On the original connector (second Pic), what are the "E" and "F". I believe the "E" is the ground from the driver side door jam switch. Where does "F" go to? I think it is the horn relay. If so, which connector on the horn relay? The third picture is the wiring breakdown from American Autowire.
st
Old Feb 24, 2024 | 11:53 AM
Wingshot's Avatar
My print shows two wires going to key buzzer switch.
My print shows two wires going to buzzer for the ignition switch
Old Feb 24, 2024 | 01:04 PM
And this is why I dislike aftermarket wire harnesses...
Since you apparently have the 1971 CSM, the pinouts for the turn signal connector are in the lower RH corner of the wiring diagram. Specifically, the black and pink/black are the wires that go to the key buzzer switch.
cfair
Sep 30, 2021 12:27 PM
neatolds
Aug 27, 2015 06:00 PM
Eaglesfan
Aug 16, 2014 04:27 PM
Othertimes
Oct 13, 2013 04:38 PM
Devon76
May 30, 2008 07:57 AM
