Turn signal switch
Old Oct 4, 2009 | 09:59 AM
convertible 63's Avatar
Turn signal switch
Big problem friends!The turn signal switch in our F-85 1963 is broken.It took me wheeks to find out there is no replacement part on the market.
All i could find is a Delco Remy,Part-Number 1993577.Not shure if it fits our car.Has anybody got a part list to find out if that one is the right switch or to get me the original Part-Number?
Hopefull,Claudia&Martin
Old Oct 4, 2009 | 07:21 PM
rocketraider's Avatar
Oldsdruid
1993577 will not work on your F85. Parts book lists it as 1963 except tilt wheel or F85.
You need group 2.895 p/n 579500, switch, circuit, 1961-63 F85. That number is also listed for 1964 all except F85, tilt wheel or cornering lamps, so you could get a used one from a 1964 full-size car if needed.
If the problem is the actuator in the steering column- 2.895 p/n 1995841, actuator, 1961-63 F85. The switch actuator rod is 2.895, 1950625, rod, switch actuator, 1961-63 F85.
If the steering column pieces are the problem, you might come out cheaper getting a complete used steering column with good turn signal components, if parts have to ship from US to Germany.
Good luck. The European guys always have my respect for owning and restoring an American car over there.
Old Oct 6, 2009 | 03:51 AM
Thank`a lot rocketraider!!!
Your answer is really a huge help to usWe will save lots of time and for shure money.
BTW We found three!!! F-85 Convertible 1963 in Swiss,one in California and two more in Germany.But the german cars are not running yet.
All the best to you and your Cars,Claudia&Martin
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
martine
Jan 22, 2009 01:13 PM
ewingr
Nov 14, 2007 09:18 PM
