Turn signal problem
Old Sep 5, 2025 | 08:22 PM
Swejen530's Avatar
Turn signal problem
I have a 1966 Olds 98 and I'm having a problem with the left turn signal not operating properly. The right one flashes but the left is solid. I've checked all the bulbs on the left side and they seem to be fine. The right side clicks from somewhere near the steering column as it flashes but the left is quiet. Anyone have or had a similar issue?
Old Sep 6, 2025 | 06:53 AM
OLDSter Ralph's Avatar
You should test the bulbs not just look at them. You could switch one bulb at a time from right to left. When the flashing switches sides, you know which bulb was bad.
Old Sep 6, 2025 | 08:01 AM
Sounds like a bad bulb. The same flasher operates both sides, so it’s good.
1969w3155
Jun 13, 2025 03:12 PM
asscutl
Sep 29, 2022 09:56 PM
jeclin
Aug 26, 2018 10:44 AM
Alg
Apr 15, 2015 09:02 PM
pinky
Sep 30, 2007 06:30 PM
