Turn signal lever install w/cruise
Old May 26, 2011 | 10:36 PM
DeltaDevil88's Avatar
can anybody help me get started on this??? kind of looking for some direction I have a delta 88 (same column setup and a cutlass) and want to install a new signal lever in, my car is also equipped with cruise.
Old May 27, 2011 | 03:45 AM
snowballs442's Avatar
Resident Eskie
What year is the Delta 88 and did it come with the signal level ? Are you replacing the old one?
Old May 27, 2011 | 06:02 AM
85 delta 88 replacing old lever
Old May 27, 2011 | 06:06 AM
Lady72nRob71's Avatar
He has an 85 Delta 88.
The service manual has a good explanation but mine is at home.
I can scan the page this weekend for ya.
Time to get a manual on order, as it seems you will be keeping this car for a long while!
Old May 27, 2011 | 08:28 AM
Thanks would love that scan!!!, are you back in town yet?
Old May 27, 2011 | 08:36 AM
Of course I am back, otherwise I would not be on the computer!
When i travel, I usually leave all things computer and work behind. Most of the time there is no access anyway...
Ping me (this thread) Sat AM or Sunday AM in case I forget. Neighbors and I will be smoking big stuffed pizzas from Papa Murphy and I anticipate there will be abundant beer consumption as well!
Old May 27, 2011 | 10:21 AM
Hmmm you owe me a wrenching lesson remember!!!! maybe we can link up soon.
Old May 27, 2011 | 11:52 AM
Yep, and here it is:
"Lefty loosey, righty tighty!"
Yes we need to, before it becomes too hot...
Old May 27, 2011 | 09:45 PM
Hit me with it whenever hope its not to extensive.
Old May 27, 2011 | 10:04 PM
Redog's Avatar
I would like like this infomation. Mine works but it's all mesed up
I think removal on the steering wheel is required, at least that's what I was told
Old May 28, 2011 | 06:41 AM
It almost looks too easy - no steery wheel removal required!
The IP sound insulator is the under dash panel. The cruise switch harness is thin with about 4-5 wires on it.
You may substitute "mechanic's wire" for regular wire. Something thin and flexible to attach to the cruise connector which will be drawn up through the column upon removal. The new switch connector will be connected to the wire and gently pulled back down through the column. Tape the connector and wire in a triangular way to reduce the chance of it hanging up on anything (avoid 90* or square angles).
Before pulling the stalk, note the position of it so you can reinstall it in the same orientation.
While this page looks cut off, there were no pictures or much else on the other page but step 6, which was "close hood". I am sure we do not care about that one...
Old May 29, 2011 | 08:29 AM
Excellent so the leve just pulls straight out the column???
Old May 29, 2011 | 09:32 AM
That's how I read it...
That is why it sounds TOO easy! Hope it IS that easy!!
costpenn
Jun 24, 2015 10:38 PM
BeenThere
Dec 2, 2014 08:29 PM
98 man
Ninety-Eight
May 4, 2014 08:07 PM
kplange
Apr 18, 2012 02:27 PM
MarkS
Jul 8, 2008 04:06 AM
