turn signal issues on 1975 Cutlass Supreme
Old Nov 28, 2017 | 01:49 PM
jkeegan's Avatar
Unhappy turn signal issues on 1975 Cutlass Supreme
I just bought a nice barn-find 1975 Cutlass Supreme, my name is John, and new on here! Problem is, my turn signals won't flash! All bulbs will light up, but not flash!! First thing I did was replace flasher, without looking ANYTHING else over! The flashers do blink, but not the turn signals! And all bulbs, when activate turn signal, stay on, not flashing!! Thanks in advance! Hope not the switch!
Old Nov 28, 2017 | 03:32 PM
Welcome to the site. Are they incandescent or led's?
Old Nov 28, 2017 | 03:53 PM
jkeegan's Avatar
Incandesant, all factory, probably most original too!
Old Nov 28, 2017 | 04:01 PM
Sugar Bear's Avatar
IIRC it has two flashers, one for turn signal and one for the emergency flasher. It's possible the wrong one was changed. Turn on the emergency flasher, hold the one you changed and see if it clicks. If it does that is the emergency flasher not the turn signal flasher.
Old Nov 28, 2017 | 04:04 PM
There are two signal stats, the one in the fuse box and one clipped near the steering column under the dash. The one in the fuse box is for the 4 ways, the one near the column is the turn signals.
Old Nov 28, 2017 | 04:08 PM
jkeegan's Avatar
Are they the same unit, just 2 of them? (interchangable)? Thank you guys! Will do it in the a.m. and let you know the outcome! Thanks again!!
Old Nov 28, 2017 | 04:09 PM
Sugar Bear's Avatar
Rather sure they interchange. If the pin/blade is the same you are good to go.
Yes same units.
Old Nov 28, 2017 | 04:10 PM
jkeegan's Avatar
Awesome!
Old Nov 29, 2017 | 12:08 PM
jkeegan's Avatar
HAPPY TO REPORT, FOUND OTHER FLASHER UNIT STUFFED UP UNDER THE DASH! "Both" were bad!!!!! Thanks again guys! Oh yeah, where do I find a Factory Air Cleaner Assembly? Trying to find the one that has the bottom filter holder, w/snorkel looking thing, and lid!
Old Nov 29, 2017 | 12:10 PM
Post a parts wanted ad in the classifieds.
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
oldschool780
May 7, 2013 06:14 AM
StarfireFan
Aug 28, 2009 03:30 PM
Willidog
Jul 10, 2009 11:09 AM
