Turn signal flasher
Old Sep 19, 2016 | 08:53 AM
fourohorsefarm's Avatar
Turn signal flasher
I have been looking for a replacement turn signal flasher for my 1976 Delta 88 Royale. The one that came out of the car is a Tung-sol 697. It is a 3 terminal flasher. My local parts stores only show 2 terminal flashers for this model. They also can't cross the Tung-Sol 697 number. Does anyone know what to replace it with?
Old Sep 19, 2016 | 10:25 AM
rocketraider's Avatar
Oldsdruid
Tell them to get their heads out of the computer and look in an accurate parts book. 3-terminal flashers are common; AutoZone website (for one) shows several available.
http://www.autozone.com/electrical-a...?checkfit=true
Old Sep 19, 2016 | 10:33 AM
Good luck with that. About the only parts store around here that still has paper catalogs is NAPA, and most of the counter staff don't even know how to find anything in it.
Old Oct 5, 2016 | 07:40 AM
I am still not having any luck finding a replacement. The only 3 terminal flashers that any of my area parts store can suggest is a "550" style. The terminal pattern does not match mine. I also can't find any cross references for the numbers on the original flasher (see earlier post). Does anyone have a parts book on this model or have a cross reference for the original? All parts store show a 2 terminal flasher for this model.
The wiring looks stock to me so I don't have any reason to think it was changed from the factory. We have had this car in the family since it was new.
Old Oct 5, 2016 | 04:06 PM
This is the only three terminal flasher pattern that I could locate on the internet. If yours is different than this, what pattern is it?
Old Oct 5, 2016 | 04:13 PM
Well, I did a search for Tung-Sol 697 and came up with some hits on ebay.
$60 for one of these things sounds ridiculous. Plus it specifically says it is not for a GM vehicle:
http://www.ebay.com/itm/New-NOS-3-Pr...567559?vxp=mtr
Old Oct 5, 2016 | 06:08 PM
Well I found a suprise tonight. After much under dash searching, I found a 3rd relay can. I did some testing and it appears that the TS 697 relay was not the turn signal flasher. Here is what is under the dash:
552 flasher(in corner of fuse block)--hazard flasher
552 flasher(hanging under dash under instrument panel,6" long wires)--turn signal flasher
TS 697(hanging off wiring harness beside fuse block,2" long wires)--???
Old Oct 5, 2016 | 06:10 PM
I searched as well, and I've got to say I'm surprised at how little there is out there.
It looks like these were used on at least all fullsize GMs starting in '76, and possibly others as well, so they should be everywhere.
I've got a '75 CSM, but not a '76, so I can't see how it's wired, but I would bet that if a schematic can be located, we could come up with a modern workaround.
edit: Cross-posted.
Looks like we really need a look at the schematic.
The 552 is probably not technically correct for the turnsignals, but should work fine.
Old Oct 5, 2016 | 07:42 PM
Danny Wiseley's Avatar
Key warning buzzer?
jpaulwhite
Oct 5, 2023 05:10 PM
costpenn
Jun 24, 2015 10:38 PM
DarrylJ
Apr 12, 2009 04:37 AM
Flye
Apr 7, 2009 02:34 AM
JPDPG
Jul 30, 2007 03:28 PM
