Troubleshooting power windows 1970 cutlass
Old Mar 22, 2022 | 10:06 AM
jozw30's Avatar
Individual switches operate properly. Driver front works from 4-position/master switch but it doesn’t operate the other 3.
Checked the switch and it appears to be working properly. 4 position switch connector seems ok.
I am thinking I’ll replace the relay next?
Any other tests I can try?
Appreciate any help!
Old Mar 22, 2022 | 10:15 AM
If ANY windows work, the relay is fine. The relay provides power to the power window system. There's only one power wire, so if the driver side window works, the relay is providing power.
Old Mar 22, 2022 | 10:18 AM
I suppose you could try the relay, but my issue was exactly same as you just described. I replaced 4-function window switch with a NOS switch and my windows are blazing fast.
Old Mar 22, 2022 | 10:20 AM
Excellent feedback by Joe. Yep, driver window worked on mine, so power was there. The other three positions simply succumbed to 50 years of oxidation/corrosion.
Old Mar 22, 2022 | 10:23 AM
This is from the 1971 Fisher Body Manual, but 70 is the same. It sounds like either the master switch is bad or the crossover harness is bad.
Old Mar 22, 2022 | 10:28 AM
Here's the diagram from 1967. Same basic wiring, but easier to read.
Old Mar 22, 2022 | 10:31 AM
BTW, you can order those door panel retaining clips online - inexpensive. I also “beefed up” with nothing more than Gorilla Tape the areas where those retaining clips fasten to the door panel hard cardboard. If you have a remote driver mirror be mindful of the cable routing there is a small hook which assists in routing (holding) remote mirror cable in place tucked up under inside the door. Finally, you may find the plastic sheet had disintegrated which covers the 4-way switch from behind to assist in keeping grime off the electrical plug-in. Use your imagination but apply a new sheet of plastic or something clever.
Old Mar 22, 2022 | 11:13 AM
jozw30's Avatar
Ok, I guess a new switch it is.
Thanks!
Old Mar 22, 2022 | 11:16 AM
You can jumper the ports in the master switch harness socket with a piece of wire. Do not do this very long. If they all work, the switch is the problem.
Old Mar 22, 2022 | 11:24 AM
jozw30's Avatar
Koda, thanks, I’ll try that
Old Mar 22, 2022 | 11:39 AM
jozw30's Avatar
Yep all 4 windows operate when I jumper the connector….
Old Mar 22, 2022 | 12:33 PM
I “think” I found my NOS switch on oldsobsolete - it’s been several years.
Old Mar 22, 2022 | 01:11 PM
gs72's Avatar
72Cutlass S
I use this on any connector that is exposed to moisture.
Old Mar 24, 2022 | 09:29 AM
BackInTheGame's Avatar
Curious: From reading this thread, Norm's Post #4 would indicate that oxidation could cause slow window movement. True? I am suffering from nearly insufferably slow window UP/DOWN, but they all work.
Old Mar 24, 2022 | 09:35 AM
Yes, by creating resistance that lowers the voltage to the motors. I have found that the most likely cause of slow windows is lack of lubrication on the guides and mechanisms. The old grease gets hard after half a century. Use silicone grease on the plastic rollers; petroleum-based greases can cause plastic to deteriorate. The second most likely cause is worn brushes in the window motors.
Old Mar 24, 2022 | 09:45 AM
Thanks, Joe. In my restoration taking place over the past eight years I disassembled, cleaned and lubed with white lithium grease, all the window tracks. I also disassembled, cleaned and lubed the motors, including cleaning the power connectors, thinking that would help - Not much. It didn't even occur to me to check the switch connections, since they all worked. I'll do that this weekend.
Old Mar 24, 2022 | 10:10 AM
Other than expanding a touch, exactly what Joe has already stated. Areas of oxidation &/or corrosion impede/hinder electron flow thereby increasing resistance (resistance decreases electron flow in these areas, reducing electron potential - e.g. weld points, dissimilar metals, moisture, etc.). It will take greater amperage/voltage in attempts to overcome resistance. As the resistance increases electro-mechanical devices eventually succumb to limited (slow movement) or no electron flow (complete failure).
Old Mar 24, 2022 | 11:38 AM
jozw30's Avatar
I ended up replacing the switches and the harnesses. Additional to the above reasons for increasing resistance thus current/load in the motors I found that the wires had strands broken at the crimp inside the connectors. One wire broke off as I tried to clean it.
Not safe at all….
Clean & lubricate moving parts, make sure glass is adjusted well (not dragging on the vertical weather strip between front and rear), etc.
It all adds up.
425HP409
Feb 19, 2021 05:13 PM
TroyLee
Dec 3, 2019 08:04 PM
kuseetha
Oct 7, 2018 09:52 PM
dingusboy
Aug 25, 2009 05:48 AM
willykmcg
Feb 23, 2007 11:50 AM
