Toggle Kill Switch - Dash
Old Feb 18, 2019 | 12:37 PM
tgilligan's Avatar
I have an MSD R2R distributor with an MSD Blaster coil. If I wanted to install a dash mounted single toggle switch to act as a kill-switch, could I wire it to the orange wire that is currently connected from the MSD harness to the negative of the coil as outlined in the MSD diagram?
Old Feb 18, 2019 | 04:06 PM
Are you installing an inline switch or a switch that grounds the "-" side of the coil? With points, grounding the "-" side of the coil is a great way to do it, because unless the thief knows about the grounded wire, no amount of hotwiring the coil will get it to start. I do not know if grounding the orange wire will damage the MSD electronic distributor, however. If you just plan to insert a switch in series in the orange wire, that will work fine. Just be aware that a jumper wire will defeat your kill switch.
Old Feb 18, 2019 | 04:30 PM
tgilligan's Avatar
Thanks as always Joe. I saw your post on a similar topic for another about grounding the points but I’m not sure either about doing any damage to the MSD distributor. My plan was to add it in the middle of the orange wire to the negative terminal to buy a little time in the event someone was trying to mess with the car if I have parked somewhere in public. Although nothing an experienced thief wouldn’t be able to overcome but more of a bit of piece of mind for me without having to install a full alarm (not saying that’s a foolproof method either).
Olds luvr
Dec 17, 2016 02:26 PM
CutLS
Aug 5, 2012 08:09 PM
yankees
Dec 1, 2011 01:39 PM
Big Todd
Oct 16, 2010 11:38 AM
47 Coupe
May 9, 2008 08:38 AM
