TH400 Kickdown switch wiring
Old Aug 6, 2012 | 03:19 AM
Pryora's Avatar
Hello all,
I've recently changed my transmission from a TH200 to a TH400. I'm running into all types of trouble getting the thing hooked up as my Wiring harness has been cut and spliced more times than Micheal Jacksons nose. I purchased the kickdown switch but don't have the bracket that attaches it to my gas peddle. Nor do I know which wires to route to the transmission. I thought that all the dash harnesses were the same and only had to find the proper wire tucked away but I have come up empty. I thought about getting the TCI kickdown switch but yet again don't know how to wire it up.
Does anyone know how to aquire the kickdown bracket for the gas peddle. any help would be apprectiated thanks. -Arnee
Old Aug 6, 2012 | 05:59 AM
The kickdown at the trans requires a switched 12v signal at WOT. Basically fab a brkt that allows the switch to close when your pedal is floored and your there, very simple!
mmurphy77
Jul 2, 2014 12:03 PM
Uncle Hulka
Apr 23, 2014 05:00 AM
Olds luvr
Feb 26, 2014 05:29 PM
AZ455
Nov 27, 2011 08:35 AM
J-(Chicago)
Nov 27, 2011 06:25 AM
