Temp Gauge Bobble
Old Jun 21, 2018 | 11:03 PM
jimjific's Avatar
Temp Gauge Bobble
Hello all,
Has anyone experienced their temp gauge wobbling intermittently? Mine (67 Vista Cruiser) has started doing this. Seems to start at idle and sometimes calms down once cruising. Any suggestions?
Thanks,
Jim
Old Jun 22, 2018 | 04:27 AM
I don't understand your description of the problem. Is it just short swings in temp, large swings in temp, or something else?
Old Jun 22, 2018 | 07:08 AM
jimjific's Avatar
Eric,
When I start the car, the needle reads properly. As it warms up, it also seems to be ok. Then usually when I come to a stop, the needle starts fluctuating (jumping around) rapidly. Most of the time, not always, as I get back to cruising, it stops shaking and becomes stable. But I have also seen it keep jittering too. The car hasn't always done this, this is a new thing.
Things I've checked:
Voltage on battery at idle - 14.5v.
Connection on temp sending unit seems to be good.
Thanks,
Jim
Old Jun 22, 2018 | 07:21 AM
Check your coolant level, it may be low causing an air pocket.
Old Jun 22, 2018 | 09:29 AM
Check the connections to the gauge in back, too. Nuts could be loose.
Old Jun 22, 2018 | 09:51 AM
My442's Avatar
Change your thermostat.
They start to behave in a weird way before the fail.
Get a Robertshaw high flow version.
Lady72nRob71
Oct 6, 2019 07:24 AM
peterzac1993
Mar 28, 2014 04:38 PM
PGH Cutlass
Oct 31, 2011 12:59 PM
1964f-85
Jul 31, 2009 07:13 PM
Sam Barrett
May 26, 2009 11:27 AM
