Tail light issues
#41
Hopefully, it should be obvious we're probing the wiring & sockets themselves to find a bad ground, etc. This does not rule out a broken, misplaced or bad wire inside the steering column but the procedure would be the same regardless. Let's test the most likely known wiring issue first by probing that yellow wire. Based on results you can then move forward elsewhere.
#42
Hopefully you're moving along getting better acquainted using the test light. I should have provided a better (different) diagram for you to follow, as well.
NOTE (below diagram): The switch feed wire (looks white I think) comes out of the headlight switch and goes into both the LH & RH parking lamp/signal sockets (red arrows). You need power on that white wire from the switch - so, test you have power on that wire to the LH & RH sockets. I'll follow this up w/ another question.
#43
So, you mentioned this previously. I can't visually see what you're referring to but I "think" it may be what you referred to in the following:
The two red circles - is that the point you might be referring to? If so, you'll most likely need to remove/separate those wires and test each individually w/ the test light to confirm. It may very well be where your issue resides. These wires (you said four of them?) may exist as a bundle in one location (might be what you're talking about) or they may exist separately. Tough determining from the wiring diagram.
In front of the radiator there is a strip of wires that have two different connection spots 4 wires on each side. Some of them wont come out due to corrosion but if sprayed them with pb blast and Ill see if I can get them loose. The ones I did get loose I touched them to another socket and the lights worked better but not correctly. Ill have to figure it out more
#44
Just cut those wires loose, then using appropriate electrical crimp connectors (maybe some extra wire) splice them back together correctly and cleanly. You should always use external rubber insulation jackets on wires. Be sure to use heat shrink insulation tubing. You'll most likely be tempted to use plain electrical tape, while electrical tape is fair to OK, heat shrink insulation tubing is the best method especially in any area(s) subject to lots of moisture & dust. It provides are a far better seal. You can buy it in any big box store, of course an automotive store will be more expensive. You can heat it w/ a heat gun or even a lighter works.
#45
You can attach the alligator clip to any CLEAN piece of metal on the chassis, engine block, frame &/or firewall - including the METAL dashboard. Since they should ALL be connected to each from the battery (-) post terminal - they are ALL the ground (-) side of your car's electrical circuitry. The entire vehicle's ground path is the bare metal of the vehicle. This then, represents why you can connect the alligator clip anywhere to bar piece of metal. It occurs anywhere there is clean bare metal (assuming your negative battery post terminal has its negative battery post terminal connected to the block, chassis, frame & firewall (NOTE: the metal dashboard is "grounded" to the firewall location). The dashboard metal is a ground (-) negative source.
With the alligator clip connected to a metal (ground) source anywhere on the car, you can then use the pointed test light probe to test for 12VDC voltage on any wire of the car. You can make that test "into" (stick the pointed probe "into") any wire anywhere on the car which comes FROM (connects to) the battery positive (+) post terminal, at the "end" of the wire you're testing, on bulb socket location, radio, horn, etc. So, to recap - alligator clip attached to any metal source = the (-) negative ground circuit of your car; when you "probe" with the pointed end of the circuit test light, you probe the positive (+) side of the circuit and the test light bulb should illuminate demonstrating a circuit path between negative (-) and positive (+). This is not the ONLY pathway to evaluate, but it is the essentials of the diagnostics to find your issue. Go ahead and try it. Take any two points where a wire should have 12VDC (like the battery you already tested you know it works). Test a head light (lights ON, alligator clip connected to metal chassis, etc.) probe the headlamp wire the light should illuminate. You're going to run this test against each wire to find your issue. The 1st place is going to be your non-functional driver side wire since your driver side parking lamp/bulb does not illuminate.
ok, I understand the concept of the test light I will try it tomorrow hopefully and keep you posted on what I find.
#46
#48
#49
#50
is it ok to just remove those connectors and use but connectors to connect each of those wires as they are now?
#53
#54
Yes. Connectors provide ease of assembly/disassembly. As I mentioned in previous post, you should use heat shrink insulation to cover those butt connectors & I see a small slice in each wire before each butt connector. I know, sounds picky, just providing you w/ best practice. At a minimum wrap those butt connectors w/ electrical tape.
#56
#57
#58
I'm "guessing" your previous pictures demonstrate the left side &/or the right side connectors? Hard to follow what I'm looking at. In any case, you have a blue wire connected to a yellow wire in one image, but the other image doesn't demonstrate a yellow wire. Someone (not surprisingly) has been into these wires before. Ensure the wires lead to their respective places via the wiring diagram.
#59
#60
You need to troubleshoot instead of ripping wires apart and reconnecting them "...back together the way they were...". Nowhere have you provided evidence of troubleshooting w/ the circuit light tester/probe. If you put the wires back together "...the way they were..." is there anything surprising why you remain having an issue?
#61
#62
me knowing nothing about electrical and just checking sockets probably isn稚 going to get me far that痴 why I posted the schematic so I could get some more advice on where to check. And I meant I connected those wires the same as they were connected before except without corroded connectors
#64
#65
remember how you mentioned that yellow wire which is the only one that doesn稚 match up with other wires? Well the light that is supposed to work for my emergency brake has a yellow wire coming out of it but there is no socket but it is a yellow wire. Could that be my issue?
#66
#69
Post 42 You need power on that white wire from the switch - so, test you have power on that wire to the LH & RH sockets.
Do you have ANY questions pertinent to Post 42? Have you tested the white wire I have repeatedly asked you to test? Is there ANYTHING you have a question about regarding Post 42?
#71
#72
You should NOT have 12VDC on any switched wire which which does not call for 12VDC. IOW, in testing your lighting, you should NOT have 12VDC on any of the switched (when the light switch is pulled out to any position) positive wires when the headlamp switch is in the OFF position only when the switch is in the ON position. If you have power to any of those wires when the switch is off, you have an issue.
#73
#74
#75
That's OK. If the test light lit up then you have 12VDC. Just be methodical about this. Test each wire as I described. Each wire along it's length in both the ON & OFF position(s). If that driver side lamp/bulb is NOT illuminating then you should NOT be getting power to the bulb. You already said this. The driver side lamp/bulb does NOT illuminate is what you have said. How then can it be if the driver side lamp/bulb does NOT illuminate you are measuring 12VDC to the bulb socket. Let this sink in.
#76
Chris - When the light switch is OFF there should be no 12VDC on the white wire. When the light switch is ON you should read 12VDC on the white wire. You effectively need to test this (with the light/circuit probe) for each wire along each wires entire path both in the OFF position and in the ON position (not ONLY the white wire, but any wire(s) - you're going to start with the white wire(s). This is what Eric suggested in his Post 2. If you're getting power to a wire which should NOT be getting power to that wire, then that wire is picking up ground from some other source (such as one light getting its ground from another light). If you get power where there should not be power you've found the issue. So, it's equally important to test (with the test light) each wire in both the ON & OFF positions. Remember, that test lamp will ONLY illuminate when there is one condition met - both a ground (-) source and a positive (+) source have completed the circuit. If that test light illuminates when it should NOT you have a ground problem.
#77
#78
Does the wire have power? Yes/No
Should the wire have power? Yes/No
#79
Thats exactly what I知 going to do tonight (clear my mind) because I知 probably just confusing myself. And tomorrow fresh start
#80
Original wire colors will be as per the wiring diagram. With that said, it's your responsibility to "trace" each wire to its location(s). What I'm saying is don't always rely on the color of the wire to represent where it goes - you have to validate the wire, not the color since after 75 years any number of people may have changed wires with any color wire. Due diligence.
