tachometer connect
Old Jul 16, 2008 | 08:30 AM
Florent.turbo's Avatar
tachometer connect
Hello, I would like to install a tachometer of a oldsmobile 1966 in my cutlass 1968 with ignition HEI, Can i directly connect the pulse of the tachometer on the point TACH of my Ignition HEI ?
Thank's for your answer.
Old Jul 16, 2008 | 08:57 AM
Yes, that's what the TACH terminal is for.
Old Jul 16, 2008 | 12:26 PM
Ok thank's Joe,i will try this.
Old Jul 17, 2008 | 09:45 AM
Yes, i have try this today ,it's great... it works
but my idle is low -> ~ 400 rpm it's normal doctor ?
Old Jul 18, 2008 | 07:19 AM
Redog's Avatar
Sound like it's not cycling correctly
Old Jul 18, 2008 | 01:01 PM
You might check your tachometer to see if there is a switch on the back of it. Sometimes tachometers will have a switch which differentiates between 4 cylinder and 8 cylinder. This could cause your tachometer reading to be bad.
Old Jul 20, 2008 | 04:06 AM
No, my tachometer comes from a oldsmobile 1966,no switch inside, but was there a tachometer for a 6-cylinder that time?
Old Jul 20, 2008 | 09:01 AM
BILL DEMMER's Avatar
Just the facts...
does it seem like the engine is actually idling at 400 rpm?
what is the reading an external tach gives you?
factory tachs aren't usually very accurate, btw.
bill
Old Jul 20, 2008 | 01:01 PM
I know you can get tachometers adjusted. If it has never been serviced then maybe 42 years have caused it to read inaccurately.
Old Jul 21, 2008 | 11:06 AM
I have to find a 2nd tachometer to compare
i thank's you all guys for your answers , i will back later
Old Jul 21, 2008 | 11:22 AM
You can generally rent a tachometer at the local auto parts store. Or at least, you used to be able to get ahold of them.
Old Jul 22, 2008 | 01:54 AM
nohn's Avatar
Where did you order your tachometer and is it the cluster tach? The set of 3 that reads your oil, RPM, and volts or water temp? I have seen a few Olds with them below the dash, but I am having trouble finding them. Thanks
Old Jul 23, 2008 | 09:01 AM
This is my tach ... he comes of ebay motors
Old Jul 23, 2008 | 11:03 AM
What does the needle do when you rev it to 8500 rpm? I thought you put a girdle and aftermarket connecting rods on your engine.
Old Jul 23, 2008 | 07:43 PM
southcarolina803's Avatar
71'OldsCutty
you can get the clusters from advanced auto, ebay, amazon, autogage are really good guages yet expensive, auto zone has a cluster set for like 32 bucs for a cluster of sunpro and i found a guy on ebay who makes classic looking housings here is a reference link to him http://cgi.ebay.com/ebaymotors/ws/eB...266025753&rd=1
Old Sep 10, 2008 | 03:26 AM
hello , i m back
i tried to connect a new autometer tach and he done ~500 rpm at idle on PARK (with AT)
How should lie idle ideal? 800 rpm at idle?
thank you
Old Sep 10, 2008 | 06:38 AM
Rallye469's Avatar
Is it running smooth?
Leave it where it is.
If it doesn't die when you put it in gear, or at a light it's fine.
Old Sep 10, 2008 | 07:18 AM
Just the facts...
iirc, the range is 550-650 in drive.
bill
Old Sep 10, 2008 | 08:02 AM
mugzilla's Avatar
is Fast Enough ...
The police get their speedo and tach calibration done somewhere . I call them and ask for the local shop .
Old Sep 10, 2008 | 01:10 PM
when I start the engine, I must push the accelerator pedal depressed slightly for a few seconds otherwise the engine stalls. engine hot or no. (i don't have a choke)
I shall check by raising a little slowed to 550-650 rpm on drive to see...
thank
Tom442
Jun 22, 2011 03:25 AM
g77rvd
Nov 13, 2010 01:49 PM
LuckyLuke
Mar 19, 2010 03:00 AM
viper771
Oct 1, 2009 05:10 PM
Flye
Jun 25, 2009 02:34 AM
