tachometer connect
tachometer connect
Hello, I would like to install a tachometer of a oldsmobile 1966 in my cutlass 1968 with ignition HEI, Can i directly connect the pulse of the tachometer on the point TACH of my Ignition HEI ?
Thank's for your answer.
You might check your tachometer to see if there is a switch on the back of it. Sometimes tachometers will have a switch which differentiates between 4 cylinder and 8 cylinder. This could cause your tachometer reading to be bad.
Where did you order your tachometer and is it the cluster tach? The set of 3 that reads your oil, RPM, and volts or water temp? I have seen a few Olds with them below the dash, but I am having trouble finding them. Thanks
you can get the clusters from advanced auto, ebay, amazon, autogage are really good guages yet expensive, auto zone has a cluster set for like 32 bucs for a cluster of sunpro and i found a guy on ebay who makes classic looking housings here is a reference link to him http://cgi.ebay.com/ebaymotors/ws/eB...266025753&rd=1
when I start the engine, I must push the accelerator pedal depressed slightly for a few seconds otherwise the engine stalls. engine hot or no. (i don't have a choke)
I shall check by raising a little slowed to 550-650 rpm on drive to see...
thank
thank
