"Super Torque Coil" in stock housing
Old May 24, 2022 | 08:18 AM
My starter guy is rebuilding a core for me. He offered a Super Torque coil that he could get for it. Said it made it really powerful. Also said it could torque the nose off with a low CCA supply from a small and/or low battery.
Anyone have experience with these?
Old May 24, 2022 | 09:46 AM
VC455's Avatar
Barely Registered
The factory had a few ways of winding the field coils. It would be interesting to get a wiring diagram and see how the Super Torque compares.
Old May 24, 2022 | 11:39 AM
The housing of high-torque starters is different from those of low-torque starters.
Old May 24, 2022 | 12:00 PM
Should have mentioned, the starter is an 1108387, hi torque, to the right on Joe's pic, and bottom left on VC's pic.
Old May 24, 2022 | 01:01 PM
VC455's Avatar
Barely Registered
1108387 and 1108389 share the same housing. However the 1108389 has the higher torque of the two.
Old May 24, 2022 | 01:05 PM
Maybe that is to what he was referring.
He did say to use a big battery with lots of CCA. He said that low batt could cause it to snap its nose....which I am wondering about.
Old May 30, 2022 | 01:13 AM
stellar's Avatar
stellar
I think the super torque coils would be fine and I don't think the nose would break if using them. Will you be using a starter support brace? The super torque coils are a little less expensive than the 387 coils and the super are a lot easier to install.The 387 coils have two shunt coils with one side of each being grounded and the other side of each going to the field lead that goes to the solenoid. That is 4 extra wires to attach and route. Take note of the threaded hole on the side of the field case. If you are using this, the super coils may be under the hole and if the bolt you put in is any deeper than the thickness of the case it may ground out the fields.
Old Jun 14, 2022 | 12:27 PM
Understood.
I'll be adding the "heat shield" bracket that uses that hole. Does the brain trust remember the specs on the bolts used for it?
oilcanman
Feb 22, 2022 02:49 AM
JPinAZ
Jul 19, 2021 06:25 PM
Sporty45
Sep 2, 2017 03:29 AM
shamusj
May 24, 2015 06:19 AM
Al Graaf
Jan 13, 2012 01:39 PM
