starter wiring tube
Old Nov 3, 2017 | 01:11 PM
george landis's Avatar
starter wiring tube
1967 442. Missing non-conductive tube, located drivers side top of frame, above brake distribution block. Have original bracket, clamp on car. Battery cable, from drivers side wheel well terminal block, along with the purple (crank), and yellow (run) wires are through the clamp. Eventually these will chafe. I purchased a tube from Brandon Reynolds, but alas his are 1/2" larger than the 66-67's. He questioned me on the proper size, my bad. My 67 assembly manual has an illustrated parts breakdown in section 12, page 1.23. There are three pictures . One says: SM&FS 442 only, another says: HMT starter cable routing, third picture says: SM&FS starter cable wiring. Mine is like picture three.
I have three questions. The most important one for me is: What are the tube dimensions? (ID, OD, and length) Brandon says he can make some. Next, what does SM&FS stand for? What does HMT stand for? SM: standard manual? FS: four speed? HMT: Hydromatic manual transmission's?
I think the correct p/n for my tube is 397769 which was a replacement for 567850.
Thanks in advance for all info and hard searching for these dimensions.
George, in south Alabama.
Old Nov 3, 2017 | 03:43 PM
CRUZN 66's Avatar
Olds Fever
I would start here for more assistance...
https://classicoldsmobile.com/forums...oductions.html
Old Nov 3, 2017 | 08:35 PM
battery tube
Battery Tube. I have one of Brandon's. Unfortunately the 67's are smaller. So his doesn't fit. If I can get the dimensions to him he can make me one. Thanks for the response, and like Joe says "search is my friend".
roberer
Sep 22, 2015 09:36 AM
dingusboy
Mar 8, 2014 07:09 AM
1k442
Feb 6, 2013 02:16 AM
oldspackrat
Dec 6, 2012 02:48 AM
Bens71442
Jan 3, 2006 03:33 PM
