Starter problems
Old April 28th, 2013, 01:44 PM
Bfg
Bfg's Avatar
Starter problems
My starter makes a clicking sound when I turn the key to start. Battery is fully charged, good ground. Does this sound like a bad solonoid or could it be the starter itself? Thanks for your help!
Bfg is offline
Old April 28th, 2013, 02:15 PM
Octania's Avatar
Solenoid may be energizing, producing the click, but failing to make the high amperage connection to the starter.
Starter may have bad brushes, comm bars, or ground.
Starter support/ torque/ GROUND strap may not be in place. The starter case to nosepiece connection may fail to pass electricity...
Really need to remove and examine everything in the starter/ solenoid, unless your ground/ support strap is missing, and adding it solves your problem.
Octania is offline
Old April 28th, 2013, 03:13 PM
+1, but I would add that corrosion in the battery terminals, cables, or connections is high on the list for this sort of problem, and these (at least the "near' portions of them) can be addressed before pulling the starter.
Does it click once, or does it click repeatedly, sort of like a buzzer?
MDchanic is offline
Old April 29th, 2013, 04:29 AM
Bfg
Bfg's Avatar
Starter
It only clicks once, I'll check the battery connections once again for corrosion, thanks for your help.
Bfg is offline
Old April 29th, 2013, 05:27 AM
Single click increases the likelihood of a bad solenoid.
Check and clean terminals, etc., then if that doesn't do it, pull the starter, remove the solenoid, open it up, remove the disc, flip over the other way so the clean side is facing the contacts, remove the starter contact and rotate it 180° so its clean side is facing the disc, then put it all back together.
MDchanic is offline
Old April 29th, 2013, 01:17 PM
Bfg
Bfg's Avatar
The ground cable is the original with the end cut off and replaced with one of those that fasten to the end with a little bar and two bolts. I will see if I can clean it up and see what happens. Thanks for your help!
Bfg is offline
Old April 30th, 2013, 12:51 PM
dingusboy's Avatar
What does it mean if you are getting a series of clicks and barely turns over?
dingusboy is offline
Old April 30th, 2013, 01:00 PM
Not enough juice, usually.
Solenoid clicks on, powers up starter, which draws current from dead battery / bad connections / whatever, which steals current from solenoid, which clicks off, which shuts off power to starter, which causes violtage to go back up, which causes solenoid to click on...
MDchanic is offline
Old May 1st, 2013, 05:22 PM
1970-W30's Avatar
Spend the ten bucks and get a new ground cable, those replacement terminals that clamp on to the cable are junk and sooner or later cause problems, not to mention they are ugly....
1970-W30 is offline
Old May 1st, 2013, 09:11 PM
Tedd Thompson's Avatar
X2 They will fail and look as good as new. For a test take it apart clean it up and try again, my moneys on the battery clamp....Tedd
Tedd Thompson is online now
Old May 3rd, 2013, 05:25 PM
Octania's Avatar
I thought that NO ONE ELSE on Earth was as cheap, er, FRUGAL as I am!
Octania is offline
Old May 3rd, 2013, 07:45 PM
A new solenoid will probably be Chinese crap.
The one in there is probably a quality American unit, whether OEM or aftermarket.
I'd rather stick with quality parts.
Plus, I hate to spend money.
MDchanic is offline
chasman414
June 25th, 2020 07:05 AM
84oldsDelta88
October 9th, 2011 03:45 PM
dennisspeaks
September 24th, 2011 01:10 PM
navvet
May 23rd, 2011 02:49 PM
cutlass47
August 10th, 2009 05:59 AM
Quick Reply: Starter problems
