Starter issue
Old Sep 23, 2024 | 02:48 PM
79cut's Avatar
Starter issue
I have a 79 cutlass with a built 455 in it
the headers are so close to the starter and when I drive for 30 plus minutes and shut car off it does not want to crank cranks maybe once twice
it’s a cvr pro torque starter serial 177331
not sure if wrapping it in heat shield will solve this or what should I do ?
I just bought the car so this is new to me
Old Sep 23, 2024 | 03:38 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Wrap the exhaust not the starter. A solenoid heat shield will help.
Ensure both secondary cables are good with clean tight connections.
Ensure all grounds are good. Neg cable should be on the block.
Have the starter amp draw tested. The windings in the motor or solenoid may be cooked. The solenoid fails with heat before the starter motor will.
Pull both apart inspect and clean. Grease the rotor shaft, check brushes and the drive etc...
If the carb is getting too hot eliminate that too and this problem will go away.
Old Sep 23, 2024 | 03:41 PM
79cut's Avatar
good points
Old Sep 23, 2024 | 03:44 PM
VC455's Avatar
Barely Registered
After following DrOlds suggestions try this:
The basic issue with hot start difficulty is that heat increases the resistance of the solenoid winding and the long wires that supply it.
The simplest thing to try is wiring a Bosch 30A relay to cut down on the length of the supply wire. Disconnect the purple wire from the starter solenoid and connect it to Bosch terminal 85. Terminal 86 goes to ground with a light-gauge black wire. Connect terminal 30 to the horn relay post with 10 gauge red wire, terminal 87 (10 gauge) goes to the starter solenoid.
This fixes most hot-start problems.
Old Sep 23, 2024 | 03:57 PM
Two words - old wires. While I/we often state correctly check connections are tight/secure/clean, the fact is (and well documented) vehicle automotive electrical wires are basically designed to last 15 years. Significant deterioration occurs about the same time. You may (at first) think the wire(s) look great. Wire is made of copper or aluminum (solid or strands). Two words - heat kills. In particular, heat traversing the starter circuit takes the greatest beating (along w/ the ignition system). Internally the wire(s) becomes brittle, lose their metallic bonding & create significantly more resistance primarily as the result of heat. As the metallic bonding degrades, the resistance increases and it's often presented (called) heat soak. Rightfully so - it will soak up as much heat as you can toss at it and it will continue to degrade the metallic bonding. Best case scenario is replace each wire w/ brand new wire. You'll be absolutely amazed at the difference.
Old Sep 23, 2024 | 04:05 PM
BTW, buy good automotive wire. There are many vendors who sell automotive wire. Some are complete garbage others supreme and they produce/manufacture wire(s) in almost any color of the rainbow so you can replace w/ good/solid wire(s) with the correct color to match OEM wiring diagram.
Old Sep 23, 2024 | 04:10 PM
79cut's Avatar
good idea.
I think the main issue was a header exhaust leak and over time it’s killing the solenoid.
I’ve repaired the leak now I will wrap exhaust and see what happens. Than move on to wiring and starter.
im assuming when these windings break down the solenoid is toast
Old Sep 23, 2024 | 04:32 PM
I like beefy wire. My battery cables are sized at 1/0 (both positive & negative). You don't really "throw" power to a starter/solenoid from the battery - that thinking went out the door when we discovered electrons (1897) but a great majority still believe power is supplied through that big old gnarly red positive wire and diagrams/dialogues are still written today which state power is supplied to a system. That is false, but old habits are hard to break. What's really happening is you're completing the return pathway for the electrons from the negative battery post to the positive battery post (for negative ground vehicles) as a result of a difference in electrode (electron) potential. What is my point? That big large ground battery cable to the engine block is significantly important since it "is" what establishes electrode potential between every single device on that huge piece of metal we call a motor vehicle and the return pathway to the positive battery post.
Old Sep 23, 2024 | 07:03 PM
I like beefy wire.
"I like big butt (splices) and I cannot lie..."
Old Sep 23, 2024 | 07:07 PM
Too funny....
Old Sep 24, 2024 | 08:27 PM
I just replaced a starter solenoid and cleaned up the connections. I fixed one I will post here in a bit. I am contemplating new battery cables and a reproduction engine harness in the near future.
Old Sep 24, 2024 | 08:28 PM
The red wire got its terminal cut off, stripped, and a new terminal with heat shrink sleeve applied. One can see the giant blue engine block, the solenoid, the pos batt cable, and the three wire harness there. I have a heat shield, not on at time of picture that goes on the other side of the cables, then there is the exhaust pipe. There is not a lot of room.
Old Sep 27, 2024 | 07:34 AM
79cut's Avatar
im wrapping my exhaust and adding a heat shield to the exhaust in this area. My headers are way too close to the starter and I bet it just cooks in there. I have a feeling mine has had in reversible damage from heat. But we will see.
Old Sep 27, 2024 | 10:05 AM
HighwayStar 442's Avatar
Move the starter solenoid close to the battery. I am never going under the car again to fix or replace the starter solenoid. Wrap the starter. Never had problems again. I still can not believe why guys want to keep it on the starter. Especially with headers??
DSCF0698
Old Sep 27, 2024 | 10:08 AM
79cut's Avatar
DSCF0698
That’s my next move.
my battery is in the trunk
Old Sep 27, 2024 | 04:46 PM
Sugar Bear's Avatar
What is the purpose of the red wire on the R terminal of the solenoid? Does the car have HEI?
Old Sep 27, 2024 | 05:23 PM
79cut's Avatar
I do have hei
Old Sep 27, 2024 | 05:43 PM
Sugar Bear's Avatar
Someone jump in if they disagree but...the inner (closest to the block) solenoid terminal in the pic is the "R" terminal and was only used to supply full battery voltage to a points type coil and only supply that full battery voltage whilst cranking the engine to start. This is why I'm asking what is that red wire to/for on your '79 car with HEI.
Old Sep 27, 2024 | 06:00 PM
79cut's Avatar
I have no idea. I just got the car 2 weeks ago and I’m still learning.
thanks for pointing that out
it’s been about 10 years since I had my corvette so the whole distributor timing stuff I forgot
I just read that the Hei is a bit different beast
not sure if you can set timing on it
so far they are made with weights specific for the engine build
Old Sep 27, 2024 | 06:03 PM
Setting timing depends upon if the engine has the CCC system or not.
All OEM distributors have weights tailored to the vehicle/engine/transmission combination.
My car has an HEI distributor and I set the timing and modified the mechanical advance (weights, springs, and center bar) for improved performance.
Old Sep 27, 2024 | 06:14 PM
79cut's Avatar
how do you set timing on these Hei ?
same as points ? Just rotate it ?
Old Sep 27, 2024 | 06:23 PM
Yes.
Old Sep 27, 2024 | 07:07 PM
Sugar Bear's Avatar
Try to see where/to what the red wire goes?
Old Sep 27, 2024 | 07:17 PM
79cut's Avatar
which red wire do you see ?
Old Sep 27, 2024 | 07:30 PM
Jeff - Whose picture you looking at? John's (Koda) or the OP's?
Old Sep 27, 2024 | 08:14 PM
Sugar Bear's Avatar
Great question Norm, my bad. I was looking at Koda's. Good catch thanks!
Sorry 79cut for misleading you.
Old Nov 4, 2024 | 07:01 AM
79cut's Avatar
So after adding heat wrap to exhaust my main problem was the positive battery post
previous owner was missing the post so just the screw was sticking out of the battery than they put a wing nut to hold the wire down.
well after I installed new posts on battery the problem went away
thanks all for the tips
Old Nov 4, 2024 | 10:08 AM
Thanks for following up on the thread with the solution to the problem.
green1972
May 29, 2022 07:20 AM
gtaa9
Jul 16, 2015 11:24 AM
Bamboo442
Aug 15, 2014 05:05 AM
wz1t8k
Jul 5, 2014 10:18 AM
henryk8398
Ninety-Eight
27
Dec 13, 2012 04:32 AM
