455 starter - mini starter 10 to 1 compression
Old May 26, 2022 | 12:09 PM
green1972's Avatar
Hi , my powermaster 3655 starter died after 6 months, I thought I saw here a discussion about a mini starter that used the purple wire also, or just the easiest mini starter to install, Thanks Tim
Old May 26, 2022 | 12:48 PM
fleming442's Avatar
How "mini" do you need. I've had good luck with my Powermaster 9510. Engine is 12:1 hot.
Old May 26, 2022 | 02:11 PM
green1972's Avatar
Fleming, I had the original size one in there, just need one with more ***** to turn it over, so it looks like mini, does it use the purple wire? or what do you do with it? thanks Tim
Old May 26, 2022 | 02:47 PM
All starters use the purple wire, most mini starters do not use the yellow resistance bypass wire.
Old May 26, 2022 | 02:48 PM
green1972's Avatar
Thanks Eric, what do you do with the yellow wire ?
Old May 26, 2022 | 02:53 PM
If your running points you'll need it and there is a diode mod you can perform to make it operate correctly. If you're not using points, then cap and stow it in the harness.
Old May 26, 2022 | 04:32 PM
deadeyejedi's Avatar
^^^^this is what I did when using points I used the diode with no issues . When I converted to hei I wrapped the yellow wire neatly in the harness
Old May 26, 2022 | 04:47 PM
fleming442's Avatar
It's definitely smaller than stock, but not 4 3 Chevy small.
Yes, it has a solenoid to use the purple. I was pleasantly surprised that the parts are readily available and not crazy expensive.
Old May 26, 2022 | 05:35 PM
VC455's Avatar
Barely Registered
I've used that starter since 2004 and it still turns my 455 effortlessly and quietly.
If you're done with Powermaster, RobbMc makes a good one and is a prince to deal with. He'll even work with you if anything goes wrong in the future.
Old May 26, 2022 | 05:54 PM
HighwayStar 442's Avatar
Mine from 2006 with headers. Starts every time.
Old May 27, 2022 | 02:22 PM
tmaleck's Avatar
I have the Rob MC gear reduction mini starter in my Cutlass. It's a 10.5:1 403 with a hot Lunati cam. It's been through a flood and installed since 2015 with no issues..
Old May 29, 2022 | 07:20 AM
PatL's Avatar
This is that diode harness. I did not know much about selecting diodes, so I ended up buying one of these:
Amazon.com: Powermaster 600 : Automotive Amazon.com: Powermaster 600 : Automotive
Donaldbabineau
Feb 21, 2022 01:55 PM
mister-twister
May 2, 2021 06:52 AM
gtaa9
Jul 16, 2015 11:24 AM
70cutty
Aug 18, 2013 05:28 PM
88hurstolds
Jan 11, 2013 07:43 AM
