455 starter - mini starter 10 to 1 compression
Hi , my powermaster 3655 starter died after 6 months, I thought I saw here a discussion about a mini starter that used the purple wire also, or just the easiest mini starter to install, Thanks Tim
Fleming, I had the original size one in there, just need one with more ***** to turn it over, so it looks like mini, does it use the purple wire? or what do you do with it? thanks Tim
Yes, it has a solenoid to use the purple. I was pleasantly surprised that the parts are readily available and not crazy expensive.
I've used that starter since 2004 and it still turns my 455 effortlessly and quietly.
If you're done with Powermaster, RobbMc makes a good one and is a prince to deal with. He'll even work with you if anything goes wrong in the future.
