speedometer lights
speedometer lights
Hello all
I have an issue with my lights on the speedometer . I changed the gauge from a sifter on the column gauge to a floor shifter gauge. The troble I`m having is that my driver side turn signal light comes on a burns solid when I turn my headlights on. When I turn the dimmer switch down the turn signal light goes dimmer as well. The instrament lights don`t work at all and the high beam light goes dim as well. My question is with that gauge being used should the harness be repinned to accomadate it? the turn signal light will light and blink but the driver side stays on when the lights are on.
thanks for your help,
Hello all
If you unplugged the harness, check that any pins got damaged. Sounds a bit like a ground issue, There are some metal straps on the plastic that the speedometer mounting screws into. This is how the speedometer is grounded.
I changed the whole speedometer first, then I changed the light plate on the back from my old one,but it didn`t change anything. so I changed the whole dash harness as well to begin with. My old speedometer harness had the same setup as the new one but now I have a light on . I thought it might be a repin issue but I will check the ground. Thanks
Having the wrong bulb in one of the turn signal sockets will cause the turn signal indicator to light up when you turn on the parking lights. The 1156 bulbs have a single connector and filament and the 1157 have dual connectors and filaments. If you put a 1156 bulb in a 1157 socket it will short the parking light circuit to the turn signal circuit. That might not fix all your problems but it might fix some of them and make fixing the rest of them easier.
