speedometer choices
Old Apr 27, 2012 | 06:59 AM
1971viking's Avatar
speedometer choices
I would like to update my speedo with an newer one but there comes a few problems with that.
1. no turn signal indicators in new speedos
2. no high-beam indicator
3. no gear indicator
That is a lot to give up. What are you guys doing? Can I buy a newer speedo with any of these features?
How about rebuilding the original? That is not cheap but maybe the only way to go. The speed indicator bounces all over and I replaced the cable and trans gear. Still not good.
Old Apr 27, 2012 | 08:19 AM
hookem horns's Avatar
You mentioned changing the speedo cable and gear, but what about the drive gear in the trans tailshaft? Maybe test by connecting the cable to a power drill chuck to see if still bouncing. The plastic drive/driven gears at the trans end can get chewed up.
Could also ask for a used column shift speedo in the parts wanted section. Someone might have a leftover from doing a bucket/console conversion.
nonhog
Dec 2, 2010 09:03 AM
Aceshigh
Feb 24, 2010 07:15 AM
nonhog
Feb 21, 2010 09:21 AM
procharged70cutlass
Dec 21, 2009 08:03 PM
ImWired
Dec 19, 2006 05:40 AM
