Speedo needle
Old Mar 8, 2024 | 09:08 AM
scrappie's Avatar
Speedo needle
Can anyone tell me how to get this indicator needle off? I tried prying but don't want to break something but I think that is the only way? Must be pressed on?
Old Mar 8, 2024 | 11:47 AM
Loaded68W34's Avatar
I carefully pull up on the center while spinning counter clockwise. Spinning counter clock wise is the key. The internal stop will keep the shaft from spinning below 0 MPH. Once you break it loose, it should come off pretty easily. When re-assembling, I put the needle on at about 5 MPH and then lightly press in while spinning counter clockwise to line the needle up with 0 MPH. Hope this makes sense.
Old Mar 8, 2024 | 01:51 PM
scrappie's Avatar
Ok thx for that. Does the shaft have a twisted thread that the bites the needle ? If so wouldn’t you go clockwise to put back on? Is it knurled or something? Do you use any adhesive on the install?
Old Mar 8, 2024 | 02:57 PM
There are no threads, knurls, or splines. It is simply a press fit. DO NOT use adhesive when re-assembling. A small amount of pressure is all that is required to re-attach the needle to the shaft.
Old Mar 9, 2024 | 05:25 AM
scrappie's Avatar
OK, sounds good thx for the knowledge Tom.
Old Mar 9, 2024 | 05:47 AM
Minibike Mark's Avatar
Dinner fork works well for removing the needle.
vCode442
Jan 29, 2023 10:05 PM
Oli-K30
Feb 1, 2022 11:28 PM
maineolds
Sep 16, 2021 04:25 PM
cdrod
Jan 25, 2020 01:37 AM
wolfman98
Nov 11, 2009 05:01 AM
