Speedo needle
I carefully pull up on the center while spinning counter clockwise. Spinning counter clock wise is the key. The internal stop will keep the shaft from spinning below 0 MPH. Once you break it loose, it should come off pretty easily. When re-assembling, I put the needle on at about 5 MPH and then lightly press in while spinning counter clockwise to line the needle up with 0 MPH. Hope this makes sense.
Ok thx for that. Does the shaft have a twisted thread that the bites the needle ? If so wouldn’t you go clockwise to put back on? Is it knurled or something? Do you use any adhesive on the install?
