spark plugs gap
Old March 30th, 2015, 01:15 PM
DYSKIE's Avatar
spark plugs gap
I have 1970 455 with holley 850dp, torker intake, msd box, msd coil and non hei distributor. I going to use NGK 5858. How much should I gap spark plugs?
DYSKIE is offline
Old March 30th, 2015, 02:03 PM
.040-.045 would probably work well.
oldcutlass is online now
Old April 1st, 2015, 07:56 AM
DYSKIE's Avatar
Thank you Eric, How if i keep them at .030 what will happen?
DYSKIE is offline
Old April 1st, 2015, 08:21 AM
The advantage with running the MSD system with a hotter coil is that you can open your gaps a bit. I doubt running a narrower gap will effect it much as long as the plug gets hot enough not to attract deposits. If you start running into issues you can always remove and re-gap.
bonesbmx
June 2nd, 2020 02:10 PM
convert69
September 6th, 2012 06:26 AM
ziff396
August 18th, 2011 04:35 PM
FL1970442
February 9th, 2010 07:45 AM
66starfire
January 3rd, 2007 10:31 AM
Quick Reply: spark plugs gap
