spark plugs gap
Old Mar 30, 2015 | 01:15 PM
DYSKIE's Avatar
spark plugs gap
I have 1970 455 with holley 850dp, torker intake, msd box, msd coil and non hei distributor. I going to use NGK 5858. How much should I gap spark plugs?
Old Mar 30, 2015 | 02:03 PM
.040-.045 would probably work well.
Old Apr 1, 2015 | 07:56 AM
DYSKIE's Avatar
Thank you Eric, How if i keep them at .030 what will happen?
Old Apr 1, 2015 | 08:21 AM
The advantage with running the MSD system with a hotter coil is that you can open your gaps a bit. I doubt running a narrower gap will effect it much as long as the plug gets hot enough not to attract deposits. If you start running into issues you can always remove and re-gap.
bonesbmx
Jun 2, 2020 02:10 PM
convert69
Sep 6, 2012 06:26 AM
ziff396
Aug 18, 2011 04:35 PM
FL1970442
Feb 9, 2010 07:45 AM
66starfire
Jan 3, 2007 10:31 AM
