Signs of bad turn signal switch?
Old Sep 28, 2011 | 10:18 AM
dennisspeaks's Avatar
Been working on my car 65 Jetstar Convertible and only the left side indicator light in the speedo cluster comes on, not the right side, plus I cannot hear it ticking. I changed the bulb and this has no effect. Also the right front turn light does not work while the right rear works it is rather slow. I have checked the connectors and bulbs all look great?
Not sure if this is just a cam replacement or complete replacement, or something else I should check?
Thanks!
Old Sep 28, 2011 | 11:21 AM
Sounds like your signal stat is no good. Look around your fuse box, there will be 2 of them if you have 4 ways. Remove and replace the one for your turn signals!
Old Sep 28, 2011 | 12:47 PM
Unfortunately this is not a 4 way flasher car,
Old Sep 28, 2011 | 01:37 PM
Then it will be easy to figure out, its the only one in there!!!!
Old Sep 28, 2011 | 02:56 PM
If you are referring to the flasher that is on the clip that is supposed to be on the bottom of the dash, I already replaced that, that is why I am thinking the turn signal in the steering column.
Old Sep 28, 2011 | 03:33 PM
You changed the flasher unit under the dash and it still does not work??? Ok, lets start over, you've checked all the lamps, left and right, front and back, what happens when you select the left side?
Old Sep 28, 2011 | 03:48 PM
I was having problems with brake lights and turns so I changed the brake light switch, flasher switch and the two upper tail light sockets, one of the sockets I know was bad. Now I have brake lights and rear turns although the right is slow but no front. Nomatter what I do I don't have the right dash turn, the left is good.
Thanks for your problem solving help.
Old Sep 28, 2011 | 03:56 PM
Can you get into the sockets with a meter and see if you have voltage, as sometimes the bulb still does not make contact with the socket ends. Also double check your grounds! If you are functioning in the rear, I would believe your switch is ok!
Old Sep 30, 2011 | 08:46 PM
Thanks!
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
martine
Jan 22, 2009 01:13 PM
ewingr
Nov 14, 2007 09:18 PM
