Should wire be hot
Should wire be hot
When I put the ground wire on the battery I get a hot spark. Ignition key is off, I checked the red wire going to the alternator and has a spark whenever the ground wire is hooked to the battery with the key off. The car is a 67 cutlass. What should I check next? Thanks.
Assuming you have a bone stock car, there should be a tiny spark as the hood light lights up and the clock lurches into motion. If you're getting serious spark, something is afoot, and do like the man above said.
sykosoft
February 1st, 2012 07:22 PM
