Sensors - Oil, H2O, Fuel Where are they?
Performed all kinds of searches ... never found what I need ... new to site ... weather getting better in Seattle - gotta get it on the road!
69 Olds Cutlass S Convertible w/350 V8. When I acquired it, oil pressure, water temp, fuel guage were not connected. Found 2 loose wires under the hood - bridged to one sensor to left of Oil Filler tube ... idiot light lit up on dash ... is this the Water Temp or Oil Pressure? Depending on which loose wire I bridge, both the Water Temp and Oil Pressure light go on. Would appreciate approximate locations for both.
Also, the fuel guage is inoperative ... found some wires in vicinity of trunk NOT going to lights or pump for the top ... any tips?
The sender next to the oil fill tube is the oil pressure sender. The temp sender is on the intake manifold, usually to the left (driver's side) of the water neck. Note that the senders for idiot lights are not the same as the senders for gauges.
Jul 1, 2012 03:36 PM
auto_editor
Jul 10, 2011 11:20 AM
