Seeking HEI Distributor Cap Info
Old Feb 4, 2022 | 12:12 PM
synoptic12's Avatar
Arrow Seeking HEI Distributor Cap Info
I would like to know if brass contacts are better, or more preferred than aluminum. Aluminum has better conductivity at 61% as opposed to brass at around 28%. However, the aluminum would most likely run hotter than brass. All replies to the above are most appreciated.
Old Feb 4, 2022 | 12:17 PM
Aluminum will corrode easily, and may wear down faster (but I'm not sure about that). I do know from my experience in auto parts sales that all of the premium distributor caps and rotors use brass contacts, whereas the economy ones use aluminum.
Old Feb 4, 2022 | 04:23 PM
synoptic12's Avatar
Arrow
My car (Oldsmobile) originally was fitted with a ACDelco distributor having aluminum contacts. They say that brass lasts longer, and resists heat; which is most likely true. However, in thirty-five years of owning the same vehicle, I have experienced no heat issues, none. I'll take the aluminum which has greater conductivity: a sure spark. Thanks very much. By the way, I wonder what the racers use?
Old Feb 4, 2022 | 06:36 PM
VC455's Avatar
Barely Registered
Engr
You've asked a good question. Follow along with me as I figure out the answer.
We need to find both amperage and resistance to figure voltage loss.
At idle, an HEI spark has 60 milliamps, and it drops as rpm increases (about 30 milliamps by 3000 rpm).
We can approximate the HEI contact as a 1/4" rod, 1/2" long. That would have a cross sectional area of 10 square mm. If made of aluminum, its resistance would be 2.7 ohms per 1000 meters or 0.4 milliohms for the 1/2" length.
Brass resistivity is 3.4 times greater than aluminum, so its resistance would be 1.4 milliohms for the same length.
We can get the loss of spark voltage by multiplying amps times resistance.
So, worst-case voltage loss would be at idle. For aluminum this loss would be 60 milliamps times 0.4 milliohms = 25 microvolts (0.000025 volts).
For brass this loss would be 60 milliamps times 1.4 milliohms = 84 microvolts (0.000084 volts).
In practical terms, the voltage loss in the aluminum post would be zero, and the voltage loss in the brass post would be 3.4 times zero = zero.
So go with Kenneth's advice and experience. Choose corrosion-free brass.
Old Feb 5, 2022 | 01:46 AM
synoptic12's Avatar
Arrow
*So, is it more efficient to have more resistance (brass) rather than conductivity (aluminum) ? "Resistivity (ρ) is an intrinsic property of a material relating to the materials resistance to the flow of electrical current. A high resistivity indicates that a material is not a good conductor of electricity."
Old Feb 5, 2022 | 06:31 AM
VC455's Avatar
Barely Registered
Engr
So, is it more efficient to have more resistance (brass) rather than conductivity (aluminum)?
I didn't explain effectively.
Here's another ignition system example...
Most people use spiral core spark plug wires to reduce interference with electronics (radio and ignition boxes).
Spiral core wires with best conductivity have resistance of about 50 ohms per foot. The shortest plug wire on our engines is about 18 inches, meaning it has about 75 ohms resistance.
Compare that to the resistance of the brass HEI post which has 1.4 milliohms resistance. Therefore, the short plug wire has 54,000 times the resistance of a brass HEI post.
If you shortened that plug wire by 3 ten-thousandths of an inch you would cancel the total resistance of the brass HEI post.
The bad news is that unless you make your plug wires the ABSOLUTE shortest you can, you are adding a MASSIVE amount of extra resistance to your ignition system.
The good news is that resistance doesn't matter when amperage is so low (0.06 amps).
That short plug wire drops the spark voltage by 4.5 V out of 20,000 V available.
A brass HEI post drops the spark voltage by 0.00008 V.
An aluminum HEI post would drop the spark voltage by 0.00002 V.
Choose your battle.
Old Feb 5, 2022 | 06:47 AM
synoptic12's Avatar
A.) So go with Kenneth's advice and experience. Choose corrosion-free brass.
B.) Choose your battle.
C.) ?
RetroRanger's Avatar
72 Olds CS
Good post Gary
Old Feb 6, 2022 | 11:41 AM
synoptic12's Avatar
Arrow
I ordered two ACdelco Distributor Caps and both had bent terminals and both terminals were loose. Ordered from Amazon. In addition, the terminal heads of the Dist. Cap were somewhat charred or missing. Here are some pictures. Would a loose terminal be a detriment in terms of arcing or otherwise? I really hate to use bad ignition parts when I have to perform the labor. All replies are appreciated. I may have to find another brand. Been using ACDelco for thirty-five years with no problems.
Old Feb 6, 2022 | 11:50 AM
Loose is not good as that may compromise the contact with the rotor.
I would go to the local NAPA and get their top-tier cap.
https://www.napaonline.com/en/p/ECHR...pressionRank=1
Distributor Cap
Part #: ECH RR171
Line: Echlin Ignition
$29.49
/ Each
Old Feb 6, 2022 | 11:57 AM
synoptic12's Avatar
Arrow
Distributor Cap
Part #: ECH RR171
$29.49
/ Each
Thanks. Anywhere else I can find a Distributor Cap at less price. Kind of pricey, even with brass contacts?
Old Feb 6, 2022 | 12:27 PM
synoptic12's Avatar
Arrow
Is AIP any good?
https://www.ebay.com/itm/17412882996...Cclp%3A2047675
maineolds
Apr 23, 2021 08:52 AM
coldfire
Aug 14, 2019 09:25 AM
joe_padavano
Apr 25, 2016 07:13 AM
edzolz
May 28, 2014 08:28 PM
ddx77
Jun 5, 2010 01:20 PM
