Replacing turn signal
Anyone replaced the turn singal with crusie control button on a 72 Olds Cutlass S. My **** on the end is broke and tape together and before I order a replacment and try takiig it apart I would seek help in putting it back together.
Where do order a new cruise lever?, the things are rare as hen's teeth.
The lever screws to the turn signal switch just like a normal one. There is a wire that has to be fed through the column then plugs in under the dash. You can replace the lever by just taking the wheel off, you may have to remove the lock plate and turn signal switch to get the wire through though. You may be able to tape a piece of string or wire to the plug end under the dash then pull the old one out and use the string/wire to pull the new one through.
[quote=Bluevista;215231]Where do order a new cruise lever?, the things are rare as hen's teeth.
I was looking at ordering from Fusicks catelog, page 69 TSL715 Turn Signal Lever 1971-1977 all exc. crusie. after you mentioned hard to find I guess (exc. crusie) MEANS EXCEPT CRUSIE CONTROL????
Guess I'll need to call before ordering?????
costpenn
June 24th, 2015 10:38 PM
