removing fuse box
Old Jul 16, 2015 | 03:00 PM
neatolds's Avatar
removing fuse box
i am working on a 1980 cutlass calais and am having electrical problems,so i thought i would remove the fuse box because i noticed a lot of crud and rust and i would assume a few melted wires. i took the two screws out and unplugged the wires it just won't come loose,i didn't want to break anything,this is confusing, help.....
Old Jul 16, 2015 | 03:48 PM
Octania's Avatar
in the older models I am more fmiliar with, you unscrew the engine side two blocks and unplug them, then the bulkhead with internal wires can be removed towards the seats after removing the 2 screws holding the fusebox/ bulkhead to the firewall.
can you go to a boneyard and look at one that you don't care so much about, maybe has less stuff in the way?
Old Jul 16, 2015 | 07:29 PM
neatolds's Avatar
thanks i finally figured it out,it would be nice if they made those bolts easy to get to and all the same size. got the wiper out and boy was that bottom bolt a pain,when i took the wiring plug off it was crispy.
Old Jul 17, 2015 | 02:13 PM
Octania's Avatar
if it was easy, anybody could do it!
Old Jul 17, 2015 | 05:52 PM
neatolds's Avatar
if it was easy they would be driving a ford.
Oldscutty72
Dec 28, 2015 01:56 PM
65 starfire
Jan 13, 2009 05:13 PM
silverriff
Jul 6, 2008 04:18 PM
nickpit21
Mar 8, 2008 11:49 AM
denis
Jan 17, 2007 10:14 AM
