Rallye Pack Temp Gauge
Old Nov 22, 2022 | 11:55 AM
Rick Hodgkins's Avatar
Installed a temp/oil/fuel Rallye gauge and seem to have a high temp indicator in my 69.
Engine is running at 190-200 but the gauge is reading above 3/4.
Could be 50 or 90 degrees out, but the gauge reads this way.
Has anyone run across this before?
Do these gauges require a different sender in the intake?
Old Nov 22, 2022 | 12:14 PM
Yes.
Old Nov 22, 2022 | 12:42 PM
Yes.
aaah ha!
I don't mean the difference between a switch for an idiot light and a sender to be clear.
Well I've tried several with the same results and ohm readings correspond to temp but the gauge is still reading high.
Is there a specific part number for use with these particular gauges is the better question?
Old Nov 22, 2022 | 01:00 PM
Is it NOS or a repop? That may just be how it's calibrated.
Old Nov 22, 2022 | 01:36 PM
Not sure exactly, got it off a member.
Old Nov 24, 2022 | 04:27 AM
Back of the gauge is pretty well buried at this point.
But can anybody say if this is OEM or not?
Seen some with resistors on the back, but this one did not and used the same multi pin connection.
Old Nov 24, 2022 | 06:50 AM
rcorrigan5's Avatar
Randy C.
The rally pac gauges on my '69 are original and the temp gauge has always read low on mine - just up to the first mark from low. On the other hand, the temp gauge on my '68 always goes to just below the middle mark. Don't know why - and everything has always operated normally on both cars.
Randy C.
'68 4-4-2 convertible
'69 4-4-2 convertible
Old Nov 24, 2022 | 07:01 AM
My 85 Monte SS has always read low too, and its a numbered gauge indicating about 120 degrees.
Infared shows 190-200 at stat crossover.
I'd have this calibrated if I knew where to send it.
Old Dec 7, 2022 | 04:26 AM
First run last night, temp read is now correct.
https://midwaymusclecar.com/products...erature-sensor
Mr.Smooth
Jun 26, 2022 06:54 PM
armbrbr
Dec 30, 2021 07:56 PM
spate51
Jun 4, 2013 10:42 AM
spate51
Nov 21, 2012 10:45 AM
69'442
Feb 20, 2012 05:34 PM
