temperature gauge
Old Feb 20, 2012 | 03:12 PM
69'442's Avatar
temperature gauge
I have a 70 442 with the rally pac. I would like to set up a temporary gauge to just check what the rally pac is reading. What kind of gauge do you recommend and can I just plug it into the temp sensor on the intake? Can I do this with all three guages also?
Old Feb 20, 2012 | 03:22 PM
mrolds69's Avatar
If you really want to know what the temp is, you need a mechanical gauge. You would have to take out the sensor there now. I ran my car like that for 1 summer years ago, because I wanted to know how hot it ran. If your factory gauge is working right, it should be between a little under + a little over 1/2 way....unless it's real hot.
Old Feb 20, 2012 | 04:24 PM
Or you can plumb them both in and compare.
Old Feb 20, 2012 | 04:40 PM
69'442's Avatar
How would I do that? Some kind of splitter?
Old Feb 20, 2012 | 04:58 PM
Lady72nRob71's Avatar
For the temp gauge, just get an infrared thermometer! Get readings on the manifold by the temp sender instantly.
They are also great for other home and automotive purposes. They cost as tille as 10 bucks, too. I calibrated my rally pac with an IRT.
Oil pressure you will need to get a mechanical one and plumb in adapter to run both at once. A good plumbing shop will have the fittings.
Old Feb 20, 2012 | 05:26 PM
69'442's Avatar
I have one of those infrared thermometer. That is a good idea. Just curious, what temp did you calibrate the center of the rally gauge to?
Old Feb 20, 2012 | 05:34 PM
Thermostat temperature.
Lady72nRob71
Oct 6, 2019 07:24 AM
1carsick
Sep 9, 2013 04:29 AM
Nickthefish
Jan 27, 2013 10:47 AM
Al Sanchez
Sep 22, 2012 07:17 PM
tpawlik
May 16, 2011 05:06 PM
