69 Rallye Pac gauge questions
Anyone ever bench test a Rallye Pac gauge (not the tach)? I have 69 gauge with missing pins and a former bad attempt to solder new pins on. Any info including reasonably priced repair shop info would be greatly appreciated.
Are replacement boards available?
And finally, are the 68/69 gauge circuit boards unique or can any year Rallye gauge board be swapped in?
I bought a replacement board from Scott (oldspackrat) it worked very well, seemed much higher quality than the OEM.
You can easily test the function of each gauge by looking at the wiring diagram. I have the old Kent Moore gauge testing tool (basically a bunch of variable resistors) but other than the 0-90 of the fuel gauge, I don’t recall ever seeing resistance values for the oil and temp gauges
