Rally Pack and HEI
Old Jan 6, 2015 | 07:43 PM
Billybobl71's Avatar
Rally Pack and HEI
Bought a set of original Rally Pack to my 70 442 that didn't come with them. After reconfiguring the wiring, everything seems to work, but the tach reads about 500 rpm too low. In fact at idle it is barely moving. I wouldn't think the converted HEI would be the culprit, but don't know. Any suggestions?
Old Apr 29, 2015 | 05:06 PM
airborne1942's Avatar
I have a 1970 RALLYE 350 with a rally pack, It had an HEI in it when I bought the car, my tach at idle has a problem to, it reads about 6-7,000 rpm at idle, I have been told to send it off to have something changed inside the tach to work with HEI! Brian
Old Apr 29, 2015 | 06:07 PM
It should work fine with an HEI, double check your connections. I'm not sure about calibrating it.
Old Apr 29, 2015 | 07:11 PM
The TACH terminal on the HEI provides exactly the same signal to the tach as a normal coil connection on a points-style ignition. There should be no issue with the HEI.
Old Apr 29, 2015 | 07:17 PM
There must be something wrong inside the tach! I plan to send it off at some point and have it gone though! Brian
joepenoso
Jun 4, 2014 01:56 PM
88hurstolds
Apr 22, 2014 09:47 AM
costpenn
Dec 28, 2013 08:39 AM
Borry
May 26, 2011 08:05 AM
Omicron
Feb 21, 2008 07:36 PM
