Olds 98 rear powerwindow?
Old Jun 22, 2006 | 09:20 AM
Lars_2006's Avatar
Hi
I need help with information how to best take the rear electric window motor out from a Oldsmobile 98 Convertible 1967. Grateful for any help.
Lars (from Sweden)
Old Jun 23, 2006 | 04:56 AM
Oldsguy's Avatar
Past Administrator
Hi lars, welcome to the site. I saw your question yesterday but held back from replying because I don't want to monopolize all the posts. But I hate for anyone's questions to go unanswered, especially new people. I really don't have a specific answer for you. My initial guess would be if you can get the back door interior panel off it would give you an idea of the mechanics of the whole thing. I am sorry for the feeble attempt but nobody should go without even a "how do you do".
Old Jun 24, 2006 | 02:55 PM
Lars_2006's Avatar
Thank you for the answer and the welcome, Oldsguy. I appreciate the try.
Well, the sides of the interior is off, and i don´t get any smarter. It is four bolts that seems to hold everything, but what happen´s if i loose everything? Those things can be tricky to get in place again when they are out if that is not the correct way to do it.
So, if anyone else know´s anything, please let me know. And thank´s again Oldsguy.
Lars
Old Jun 24, 2006 | 03:54 PM
Oldsguy's Avatar
Past Administrator
How about if you use some really strong tape to hold the glass in place and slowly loosen some of the bolts, if the glass starts to drop you know to not loosen those bolts, maybe...?
Old Jun 25, 2006 | 01:37 AM
Lars_2006's Avatar
Yes, that could be a possibility.
Anyone who know´s if there are any "do it yourself books" that i can download on the net, or something like that?
Old Apr 29, 2015 | 03:56 PM
billwaldo's Avatar
does any company reproduce the window switches and seat switches.some of the wires have snapped off of the spades.I don't see any way of getting the switch apart.would it be easier to do homemade reconnections.wires themselves look ok.any help?
Old Apr 29, 2015 | 04:53 PM
m371961's Avatar
Bill start a new post with year and model. Maybe one of the Mods can move this post. There is a sticky post in the electrical forum that has good info on the switches.
Old Apr 29, 2015 | 07:54 PM
Charlie Jones's Avatar
Phantom Phixer
The 1967 Fisher Body Manual should tell you what you want to know .
You can get one on E-Bay here;
http://www.ebay.com/sch/i.html?_from...anual&_sacat=0
Old Apr 30, 2015 | 03:38 AM
Yellowstatue's Avatar
Leave the motor attached to the regulator. Support the glass at the top of it's travel. Then remove the four bolts that hold the regulator in position, and then wiggle waggle the whole assembly out the access hole. I think the regulator should be in the 'up' position to make it easier to remove. After it is out of the car, clamp the regulator or drill a hole for a 1/4" bolt to hold the regulator from collapsing from the spring tension and then remove the motor. On a full size car there might be a roller rail attached to the inner panel to guide the glass, two bolts.
Old Apr 30, 2015 | 05:14 AM
m371961's Avatar
Guys, the rear window post is from 2006. I make the mistake of answering an old post too.
Old May 1, 2015 | 02:50 AM
I'm still waiting for a positive result.
monzaz
Jan 13, 2013 05:33 PM
monzaz
Oct 2, 2012 04:49 AM
orthoK
May 16, 2011 10:10 PM
Nor Cal Andy
Apr 1, 2011 07:13 PM
