Rally pack on a 72 442 350
Hi all,
I read through the rally pack sticky and unless I missed it I’m looking for the point on the distributor to hook the wire to.
on my distributor there seems to be an empty space with tach marked on it. This may be stupid simple but I don’t want to blow anything up.
So I’m finishing the wiring up on the rally pack and have everything all set and I’m wondering the brown wire from the coil goes to the back of the tack marked coil but the braided cable also has an eyelet on it where does that go
and I’m assuming the orange wire I just cut the terminal off and put an eyelet on there as well
so am I correct in attaching the one end to the Space labeled tach ? And can I mount the ground strap to the guage mounts, I assume they are grounded with the metal straps that are present?
