Rally pack on a 72 442 350
Old Jan 26, 2020 | 09:33 AM
Hdmike444's Avatar
Hi all,
I read through the rally pack sticky and unless I missed it I’m looking for the point on the distributor to hook the wire to.
on my distributor there seems to be an empty space with tach marked on it. This may be stupid simple but I don’t want to blow anything up.
Old Jan 26, 2020 | 09:49 AM
I'm assuming your looking for where to connect the tach? If so, it would be the terminal on the hei distributor marked tach.
Old Jan 26, 2020 | 10:14 AM
Hdmike444's Avatar
That’s what I thought but wanted to confirm
Old Feb 8, 2020 | 11:39 AM
Hdmike444's Avatar
So I’m finishing the wiring up on the rally pack and have everything all set and I’m wondering the brown wire from the coil goes to the back of the tack marked coil but the braided cable also has an eyelet on it where does that go
and I’m assuming the orange wire I just cut the terminal off and put an eyelet on there as well
Old Feb 8, 2020 | 03:57 PM
Dave26's Avatar
At some point, someone installed and HEI distributor in your car.....The braided cable with the eyelet was for the coil bracket back when your car had a points distributor.
Old Feb 8, 2020 | 07:08 PM
The braided part is connected to ground at the fuse side only. The other side of the braid is connected to nothing.
Old Feb 8, 2020 | 07:14 PM
Hdmike444's Avatar
I was assuming it is grounded but with the little length provided where is it supposed to go? Is there a specific location?
Old Feb 8, 2020 | 07:48 PM
Hdmike444's Avatar
so am I correct in attaching the one end to the Space labeled tach ? And can I mount the ground strap to the guage mounts, I assume they are grounded with the metal straps that are present?
Old Feb 18, 2020 | 06:49 PM
Hdmike444's Avatar
All up and working properly!
Old Feb 18, 2020 | 06:55 PM
Glad it worked out.
kbdecatur
Jan 28, 2019 03:51 AM
mikejana
Mar 14, 2018 01:03 PM
firefighter5174
Jul 18, 2016 06:38 PM
neatolds
Aug 26, 2015 06:01 PM
firefighter5174
Jan 16, 2012 04:20 PM
